I am trying to rip my first DVD from the camcorder, i have th drivers it appears to communicate with the PC, I can eject the dvd using the dvd decrypter software so apears to be communicating. I am following the direction from this page below:
http://www.videora.com/en-us/Converter/guides.html
When I get to step 5 i cant select the enable stream processing box it is greyed out. Below is a log i copied also. Looking for help.
I 18:27:34 DVD Decrypter Version 3.5.4.0 started!
I 18:27:34 Microsoft Windows XP Media Center Edition (5.1, Build 2600 : Service Pack 2)
W 18:27:34 Drive D:\ (FAT32) does not support single files > 4 GB
I 18:27:34 Initialising SPTI...
I 18:27:34 Searching for SCSI / ATAPI devices...
I 18:27:34 Found 1 DVD±RW and 1 DVD-RAM/RW!
It is telling you why
You have told it not to split files, however because you have FAT32 you cannot accommodate the file it needs to create. The best option is to convert your filesystem to NTFS. Windows has an option to do this.Drive D:\ (FAT32) does not support single files > 4 GB
Otherwise you will have to split your file into smaller chunks. -
Thanks for the help, is that an extreme solution? id be worried about losing data. Do i have any other setting options or other similar freeware software programs that might work?
It's not difficult, however there is always a small risk of losing data, so back up first. I have done this on several machines without incident.
Here is the official word on the process
http://www.microsoft.com/technet/prodtechnol/winxppro/maintain/convertfat.mspx -
So what happens after that?
It also says Disc is empty in lower left corner
Do I need to re download software etc? this stuff is making my head spin
Would getting a DVD drive that plays mini added to by PC be better the attaching the camcorder??
Looking for more help. -
Nothing. All you are doing is changing the file system that is used to store files on your HDD. However NTFS is a much smarter, faster file system than FAT32, and will allow you to store much larger files. All your software will continue to work, but now DVD Decrypter will be able to demux the entire stream for you.
any reason this wont stream on xbox360
By carlos28355 in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2009, 21:17 -
Got ripbot working, BUT it wont stream to my PS3
By Fiostech in forum Blu-ray RippingReplies: 5Last Post: 5th Feb 2009, 12:15 -
How To Enable PC To Read DVD-R
By Jjay in forum Authoring (DVD)Replies: 10Last Post: 5th Jan 2009, 16:47 -
DVD Decrypter wont work with my external drives?
By dazza555 in forum DVD RippingReplies: 4Last Post: 23rd Jun 2007, 19:04 -
WMP11 wont stream
By wayneyg in forum Newbie / General discussionsReplies: 18Last Post: 2nd Jun 2007, 03:09
