    Aug 2001
    Colorado, USA
    I was wondering if its possible to remove a watermark, and add my own??? I have searched the forums and found nothing but how do I add one and how do I remove one. Would I have to Remove it first, then add my own???
    By the way if I do this, I would have to use Virtual Dub right? Is there another program anyone knows about????
    What the Fuc is the internet?
  2. VirtualDub would be a freeware solution. You could apply the DeLogo filter and remove the watermark. You could then apply the Logo filter to put your own.
    Other Editing packages like Adobe Premiere 6, should also be capable.
    Aug 2001
    Colorado, USA
    where can i get the delogo filter?? I have the logo filter..... ??
  4. this link should help you.
    http://sauron.mordor.net/dgraft/
    Check out "Hosted filters and tools"
    Aug 2001
    Colorado, USA
    thanx man.. I think i found everything i need.
