hi guys im new to this forum and i hope u can help me,
i wanted to connect my laptop (acer aspire 5611) to my tv so i purchased an s-video to rca (my tv dosnt have an-s video input) adapter and connected them both and i can see the desktop on the tv and it plays video files fine the problem is that its all in black and white !! i cant get colours on the tv i tried to play with the colour setting on the pc card but when i select tv from the menue every thing is disabled (i.e u cant change any value) so i'd really appriciate it if u can help and tell me whts wrong and how to fix it ?
Tried switch between PAL and NTSC? But I guess it wont help, see https://forum.videohelp.com/viewtopic.php?p=1364076#1364076
Not all of these cables actually connect s-video to composite. All you are getting is the luma signal, hence non-colour.
thanx guys fro the replies, i tried changing the system from pal to ntsc but no use, any other suggestions !! i would really appreciate it ,thanx . ps what is a luma signal ?
composite mixes the colour and brightness (luma) into one signal. s-video separates them out. Component takes the separation even further. The cable you have used is only passing the brightness down the line, but no colour. It is only an s-video cable with an RCA head at one end, not a converter.
What you need is one of these : http://www.ramelectronics.net/html/svideo-rca.htmlRead my blog here.
Colour Conversion problems with Avisynth
By wiseant in forum Video ConversionReplies: 6Last Post: 16th Mar 2011, 11:40 -
Monitors and colour.
By dfgh11 in forum EditingReplies: 3Last Post: 6th Jan 2011, 10:44 -
Problems with subtitle font and colour
By skp61 in forum SubtitleReplies: 5Last Post: 29th May 2009, 19:29 -
FFDShow Big Colour Problems
By Endemoniada in forum Software PlayingReplies: 3Last Post: 28th Feb 2008, 22:19 -
Deep Colour/xvYCC colour/x.v.colour confused consumer
By ArthurDaley in forum DVB / IPTVReplies: 10Last Post: 9th May 2007, 18:10
