Dear all,
I'm trying many and many times to find program to rip my DVD and put it in one file with exact size I chose it???
each time I try to rip the DVD it is come to 2 or 3 file with the size I chose it...
I mean I user ImToo, SimpleDvix and DVDx to rip my DVD to one file with 700 MB,
but each time it comes to 2files with 700MB and 700MB with total of 1400MB...
pleas help me?? How can I rip all dvd to one file with 700MB and good quality?
thanks for all,
but can I know what is the best setting for the codec to use it if I try Dvix...
thanks again... -
AutoGK is, as the name implies, automatic. Just open the IFO in it, leave everything else alone, except for maybe specifying the codec, the size you want, and any subtitles, and come back when it's finished. If you have any problems with it, post the log file here after the encode. If you like it, let us know.
By the way, for best results, get your movie onto the hard drive using DVD Decrypter in IFO Mode (up at the top, Mode->IFO), which isn't the default setting. If you have a recent movie on DVD, one that has one of the newer protections on it, better might be to use RipIt4Me in Movie mode. -
No, as "best" is subjective. The "Auto" in AutoGK will do a very good job, but likely there can be a better setting. However, I'd think it takes quite some skill and experience in configuring thecodec to beat what AutoGK does.Originally Posted by za3tar
/Mats -
Dear mats.hogberg,
thanks for ur reply, I all ready use FU Wizard and the output file is what I look for it.. but the quality not to much...,
I download one file from P2P program and it was 702MB and the quality as like as DVD. How it is happen I will die to know?????????
How to get output file size before converting a file using ffmpeg?
By hayden in forum ProgrammingReplies: 1Last Post: 26th Feb 2012, 07:04 -
WinAVI output file size
By Akusai in forum Video ConversionReplies: 21Last Post: 5th Oct 2009, 06:54 -
different output file size in convertx2dvd
By Iwan2learn in forum Authoring (DVD)Replies: 13Last Post: 13th May 2009, 02:29 -
Video Conversion - output file size
By Leo48 in forum Newbie / General discussionsReplies: 2Last Post: 19th May 2008, 07:28 -
Controlling CCE's output file size.
By astrocity20 in forum DVD RippingReplies: 24Last Post: 13th Dec 2007, 22:32
