i've downloaded a few videos from savetube, but my computer wont play them, any idea what it would have been saved as, and how i can get a player that will play them, or convert them so i can burn them to dvd?
grateful for any help i can get
thanks.
flv files? Then try google for "flv player", like http://www.wimpyplayer.com/products/wimpy_standalone_flv_player.html or play with VLC Media Player. To convert to DVD use ConvertXtoDVD.
According to a Google search....savetube saves vids from YouTube...which should have .FLV at the end of the file name....if they do not have .FLV at the end...put it there by right clicking on the file and renaming it.
Then get a free .FLV file player like Riva FLV Player.
The videos on YouTube are VERY VERY low quality and will NOT look good if you do manage to find a way to convert them to DVD. -
The file extension is the last three letters after the dot on the filename. You will have files called myfile.avi, or myfile.flv, etc.
However, your computer may just show them as myfile. If this is the case your computer is still set in TellyTubbies mode. To show the file extensions open My Computer, click on Tools, Folder Options and click the View tab. Part way down you will see "Hide extensions for known file types" which will have a tick next to it. Remove the tick and the file extensions will then be displayed. -
Trying to get some vids using savetube but after watching the tutorial and pasting the link, there is no GO button. There is a get video button tho and i push it and nothing happens. Any ideas?
OK, now a day later, the go button is there but will do nothing when i click it.Last edited by mac71671; 19th Apr 2010 at 21:29.
SilverCrest - Saves as AVI?
By Okay in forum Newbie / General discussionsReplies: 8Last Post: 21st Oct 2011, 01:53 -
change aspect ratio in mp4box saves a few megs?
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 10th Aug 2011, 04:19 -
M4V to AVI in VD, when compressed with Xvid, saves with audio out of sync
By kiki hayes in forum Newbie / General discussionsReplies: 4Last Post: 4th Aug 2011, 09:45 -
Vegas Movie Studio Platinum 9.0 saves projects wrong!!!
By TonKhaO in forum EditingReplies: 0Last Post: 12th Apr 2009, 07:59 -
DVDFabdecrypter saves as .iso?
By magicfingers in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2008, 08:01
