Im confused..
i have XP installed on my HTPC which played everything flawlessly. AC3/DTS over S/PDIF worked a treat and the amp changed and played the streams.
However, my installations stopped playing xvids, and explorer crashed on clicking on them etc,etc, (reinstall of xvid didn't help), anyway decided to install new XP, so its clean, fast and none of the crap from before (when it wasn;t a HTPC)
I installed a new version along side the current to save any headaches.
So installed XP, xvid, codeavc, MPC. Installed all the sound drivers etc etc..
However, when i play a movie it will NOT output DTS/AC3 via optical, even though I have compared the settings on the 2 machines..
What im finding is that if i (in MPC) select filter, DTS, AC3 and try and put them to use S/DPIF, on restart it says it missing a codec?
This doesn't make any sense.. anyone got any ideas at all..
SYNC PROBLEM: X264 AC3/DTS MKV --->>> Xvid with VBR mp3?
By Randm in forum Video ConversionReplies: 6Last Post: 30th Jul 2013, 17:57 -
Dts to ac3
By vagos13 in forum Newbie / General discussionsReplies: 13Last Post: 5th Jan 2013, 20:29 -
DTS to AC3 audio conversion (using MP4Tools on a Mac) issue/problem
By SimonSimon in forum AudioReplies: 1Last Post: 1st Sep 2011, 04:41 -
Weird problem during the DTS -> AC3 convert
By maciex47 in forum AudioReplies: 2Last Post: 6th Nov 2010, 09:40 -
Reauther dvd with pcm & dts to ac3 & dts
By djblade in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2010, 08:40
