Okay - lets take the DVD Player, the burning software, and the DVD media out of the equation. All things being equal, when I go to burn this VIDEO_TS folder to a DVD (properly) and make a playable DVD in my standalone player everything burns great - no errors. When I stick this DVD (not Divx, or any other VCD blah blah format) into the standalone it doesn't play, in the PC it plays. ANY other standalone will not play this DVD either. This same media works on all these same standalones with a "good" VIDEO_TS folder. Am I making sense? This appears to be some kind of menu problem or something because when I double click on the .vob files in the PC they pull up the menus and everything is swell.
There are several ways to approach this... 1) how do I find out if a VIDEO_TS folder is going to work on a standalone (menu problems etc) before I try and burn it? 2) What is the best way to fix any problems that exist with menus etc before I create another coaster? 3) Is this something that actually made sense and can someone fill in my many blanks?
Thank you in advance!!!
Results 1 to 14 of 14
Originally Posted by heuster
2) Open the Video_TS in PGCedit "Trace Mode" then read all the guides.
3) When you've finished, make another DVDRW test disc and see if that works. If not, repeat step 2. -
Originally Posted by ntscuser
DVD inserted: "E:\Recording\Video\genericvid\VIDEO_TS\"
DVD inserted: ""; Provider:
DVD inserted: Resetting all GPRMs to 0.
DVD inserted: Initializing the SPRMs to default/setup values.
------> Entering VMG , First-Play PGC
-- pre 1 : (JumpSS) Jump to VTSM 2, Root menu (TTN 1)
-> sprm(5:Title number in VTS) = 1 (0x0001)
------> Entering VTSM 2 , LU 1 (en) , 1 (0:07) 7b. RootM
-- pre 1 : Set gprm(6) =(mov) 99
-> gprm(6) = 99 (0x0063)
-- pre 2 : Set gprm(14) =(mov) 99
-> gprm(14) = 99 (0x0063)
******* Start playback VTSM 2 , LU 1 (en) , 1 (0:07) 7b. RootM...
******* Playing Program 1, Cell 1 (0:00.12 + infinite pause) (7 buttons)
-> sprm(8:Highlighted button number) = 1024 (0x0400) = button 1
Selected menu button: 1
-- button : Set gprm(3) =(mov) 1 ; LinkPGN Program 2
-> gprm(3) = 1 (0x0001)
If I step through this, it works just fine and the video plays etc. I can't seem to find out what is missing so this will work in a standalone. -
Try running the vobs through gspot or vdubmod - NTSC is 720x480 PAL is 720x576. You can also use a software dvd player like mpc to check on the resolution.
Changing from PAL to NTSC the proper way requires re-encoding. And I'll point you to a couple guides but let's eliminate if it's a PAL/NTSC format problem first. -
I'll point you to this PAL-to-NTSC guide by Fulcilives:
https://forum.videohelp.com/viewtopic.php?t=300144
It is strictly the movie video getting re-encoded. You will lose any menus though.
There are other so-called patch methods that are easier but doesn't always work on standalones. Then there are more complex methods while keeping menus.
But the easiest way is to get a dvd player that can play both.
Can someone tell me how the VLC player's recorder works?
By gastrof in forum Newbie / General discussionsReplies: 7Last Post: 3rd Apr 2014, 03:17 -
burning an xvid video file to play on dvd player
By Meggie in forum MediaReplies: 8Last Post: 9th Sep 2009, 07:26 -
DVD burning nightmares...it no longer works???
By apollo1980 in forum Authoring (DVD)Replies: 1Last Post: 27th Dec 2008, 16:22 -
Sound works on Pc but not on Dvd player
By Rogert in forum AudioReplies: 4Last Post: 7th Jun 2008, 07:22 -
Media Player that works with MCE Remote
By TBoneit in forum Software PlayingReplies: 2Last Post: 30th May 2007, 16:13
