I have captured some video from a hi8 source and have to crop some of it,I want the final video to be full screen.Should it be 640X480? and what resizing method would give me the best quality?Bicubic?I am using virtualdub.
On what? And played via what?Originally Posted by BirdDaddie
For reduction Lanczos3 is the best choice. For enlarging Bicubic or Lanczos3.Originally Posted by BirdDaddie -
Do you realize that televisions overscan the picture? So you don't see the edges of the video anyway. If you crop away the edges then enlarge what's left you will end up seeing even less of the picture when you watch on TV.
If there's noise around the edges (video tape caps will usually have noisy garbage at the bottom) you can use the Fill function to overwrite it with black rather than cropping. Black borders eat hardly any bitrate. -
720x480 is the resolution. Setting your encoder to encode as 16:9 or 4:3 determines if it's WS(16:9) or FS(4:3).
16:9 and and 4:3 both use 720x480, the aspect is adjusted by the DVD player or whatever software you are using to play it back. **That's providing the right flag was set and the software repects it.
Click the link for DVD specs under "what is" in the upper left.
Want to resize an avi
By janlafata in forum Video ConversionReplies: 2Last Post: 17th Aug 2009, 23:06 -
MT2S - Resize
By HamishT in forum Video ConversionReplies: 4Last Post: 19th Jul 2009, 21:15 -
Resize HD to SD
By ron spencer in forum Authoring (Blu-ray)Replies: 9Last Post: 1st Jan 2009, 12:52 -
.sup resize...
By alcOre in forum SubtitleReplies: 1Last Post: 1st Dec 2008, 03:57 -
can I resize using virtualdubmod
By thecrock in forum Newbie / General discussionsReplies: 5Last Post: 22nd Oct 2008, 16:54
