I'm running Win XP pro on an ASUS motherboard with 512Mb PC2100, processor is Athlon 1600+.
I having real problems with the Radeon card when I select "best quality" using the mmc and then capture the results are poor. The sound gets distorted and dropped at times. Weird, in other lower quality modes the sound is fine. Problem is, I need to be capturing at the highest resolution though.
Also strange is that I downloaded MMC 7.2 and installed this yet when I click on the launchpad "about" it reveals that it is 7.1, same with the TV viewing application, on opening it up it says "7.1".
I've taken advice from "how to" section on VCDhelp which is great but nothing is making life easy. I've used Vitualdub to capture but at DVD quality I'm getting far too many dropped frames.
Anyone got any ideas? Much appreciated
Have you installed the via pci latency patch ?
You can also try making a custom preset using 22kHz instead of 44.1kHz. -
I had the same problem. According to ati support, the problem is not in the capture but in the DVD player. They suggested using a third - party dvd player for any meg2 captures. I'm using WinDvd and it's working without any problems. I'm also using MMC 7.5
Are the Lions for real? 26-23 win over Vikings (NFL)
By yoda313 in forum Off topicReplies: 21Last Post: 24th Oct 2011, 10:44 -
trouble playing this file in WMP in Win XP sp3
By charlieship in forum Newbie / General discussionsReplies: 13Last Post: 26th Jun 2011, 08:10 -
Trouble Playing Real Media Video
By -phenom- in forum Software PlayingReplies: 5Last Post: 4th Oct 2010, 10:19 -
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 03:12 -
Win 7 and XP dual boot issues. Can't access one of the drives in Win 7?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 13th Jun 2009, 23:51
