I have been creating subtitles with SubMagic, then importing them into DVDLabPro. All seems OK except that the titles need to be a little higher on the screen. Especially where a sub has two lines of text, the lower line is not visible at all. I click on the Sub window, and import the subs into DVDLab. There is a Margin button and when clicked on to open, it reveals both Margins Settings and Base Line Alignment (Bottom Margin Middle Margin). Can anyone explain what these settings mean, as the manual is a bit hazy on this subject.
Are these the settings used to move the subtitle up the screen ??
Also, is the Font and the screen position defined in the subtitle creator, and/or does DVDLab override any such settings ??
Thanks in Advance
Zen
Srt files don't hold the positions, neither the font. It's only a text file with the timings.
The fonts and positions in SubtitleCreator are here only for binary files like SUP or VobSub that can be created from srt files.
Cheers
Manusse -
Thanks for the replies so far
It's beginning to make more sense as I move onward throught the fog
Any info on the DVDLAB Pro Margins question (above) ??
Zen
Chinese & Serbo-Croatian subtitles corrupted in DVDLab Pro
By umforrest in forum Authoring (DVD)Replies: 3Last Post: 27th Aug 2011, 13:17 -
Problem with subtitles off by default in DVDlab-pro
By blajko in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2010, 19:21 -
Overlapping subtitles on DVDLab Pro
By ikarishinji41 in forum Authoring (DVD)Replies: 3Last Post: 18th Jun 2010, 03:06 -
Subtitles in DVDLab Pro 2
By lorix in forum Authoring (DVD)Replies: 13Last Post: 13th Nov 2008, 14:09 -
VCD to DVD with subtitles in DVDlab Pro - subs 'disappear'...
By nbarzgar in forum Authoring (DVD)Replies: 0Last Post: 11th Jun 2007, 10:16
