Dear forum
A friend had a vhs videotape and managed to make a dvd-video from it that could be watched on television using a standalone dvd player.
The quality is quite good, except that the sound volume level is a bit lower than I would like (even when you turn the sound up on the TV)
Since I am a bit hard of hearing this is more than a nuisance. Therefore I would like to know if there is anyway one can produce the same dvd but with higher sound level
Any help would be appreciated please
Ian
ian c
You can increase the volume on your computer and then reburn it on a new dvd.
https://forum.videohelp.com/viewtopic.php?t=318958&highlight=increase+vol+volume+dvd -
HI Thank you for this prompt reply!
I shall ask him to do this using the original mpeg file he used when he authored the dvd and then once the sound is higher he will be able to re-author it.
On the dvd the sound was a little out of sync with the video - please do you know how he might fix this also
Thank you
Ian
DVD audio volume too low
By efiste2 in forum AudioReplies: 4Last Post: 28th Mar 2012, 17:06 -
Low audio volume
By Daz_uk in forum Capturing and VCRReplies: 0Last Post: 29th Jan 2010, 14:34 -
DVD footage with low volume CAN WE FIX IT ??
By rockonvidtrade in forum AudioReplies: 7Last Post: 11th Jan 2010, 12:27 -
DVD volume too low on TVs, but is fine in VLC on my PC. Fixes?
By JesterPoet in forum Newbie / General discussionsReplies: 3Last Post: 22nd Sep 2009, 11:18 -
volume too low on video file
By sepultura in forum Newbie / General discussionsReplies: 2Last Post: 28th Jan 2008, 02:46
