Hi,
Not too sure how i should explain this but here it goes...
I would like to rip a dvd into a single file that can be converted over to a iPod video compatible format (mp4).
So far i've managed to rip a dvd by just converting (with Jodix iPod Video converter and with Cucusoft Dvd to Ipod Video Converter) the vob induvidually into separate mp4 files, problem is that i end up with a number of files...instead of a single movie file.
I've also managed to rip a dvd to my hard drive (with Ripit4me / DVD Decrypter)...but they are still as separate vob files that will create separate mp4 files...again...
I've tried joining the mp4 files in Yamb but the end format doesn't seem compatible with my 30g video iPod.
Does any one have any good suggestions for a "simple" process / program..??....if there is such a thing...
Any help most appriciated
Fred
DVDDecrypter can rip to one file (set file splitting to none in file mode) if it's a disc DVDDecrypter at all can rip. Or else, run your VOBs thru vob2mpg to get one continous mpg from the VOBs
/Mats -
....hey, what do you know...it works like a charm!!!!!
Tack for hjalpen...hall pa att bli tokig..!!!
(thanx for the help....was going crazy!!!)
faster blu-ray to dvd single layer conversion
By Steve(MS) in forum Blu-ray RippingReplies: 11Last Post: 10th Aug 2011, 21:02 -
Encode single file compatible with both iPod/Symbian/Android and PSP.
By x2x3x2 in forum Video ConversionReplies: 2Last Post: 24th Nov 2010, 00:17 -
File Converted by Handbrake (0.9.3) Using iPod Preset Won't Play on iPod
By GrayStrickland in forum Video ConversionReplies: 0Last Post: 8th Mar 2009, 20:56 -
DVD to single file...
By kevinp in forum DVD RippingReplies: 5Last Post: 7th Jan 2009, 20:54 -
DVD to ipod Conversion Problem
By Cirone328 in forum Newbie / General discussionsReplies: 1Last Post: 19th Jul 2008, 11:29
