I have a few Divx avi files that are at 23.98 fps. Basically I want to get them to DVD. Heres what I tried:
1. Regular toast DVD encoding: abysmal quality
2. Regular iDVD encoding: horrible quality
3. ffmpegx encoding: (encoded with both mencoder and ffmpeg in FILM setting) GREAT quality but stutters on apples dvd player
4. sorenson squeeze to mpeg2 (29.97) to toast dvd authoring: looks great on apples dvd player, slight stutter on two tv dvd players.
So I think my best bet is going with ffmpegx, but I just dont know which settings to use. The files are 640x348, what "autosize" should i use. what framerate should i set ffmpegx on? what video bitrate should i use? should i enable the 3:2 pull! help me out im just a n00b!!!
What type of stuttering ? If you mean jerkiness in pans and zooms, I would suspect encoding at the wrong framerate.
If you source is 23.976 fps, encode at 23.976 fps and add 2:3 (or 3:2) pulldown. This should smooth out the problems.
Coming from a windows world I only know of Windows based resize calculators - such as FitCD or my own. However a quick google came up with this : http://www.xeep.net/tools-for-video-aspect-ratio-calculator/
Bitrate is wholly dependent on length, and you can use the online bitrate calculator here : https://www.videohelp.com/tools?tool=VideoHelp_Bitrate_calculator to work it out. -
Exactly.Originally Posted by hmg
With the pulldown, the stutter is gone when played in Apple DVD Player.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 13:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 05:48 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 10:24
