Hello, I am trying to splice together a version of the the first LoTR movies with a mixed audio track combining the original 2 channel stereo sound track and the Rifftrax by the amazing Mike Neslon. I was able to Demux the audio to ac3 send it to wav use audacity to combine the audio now I'm trying to author the dvd in TMPGEnc dvd author and I keep getting the error that the video stream I created by using DVD decrypter then used PcgDemux to to create a .m2v file that plays fine in windows media player, media player classic to too high a bitrate to use and a decoder cannot be actiivated. if anyone could please help me out by suggestion a differnt DVD authoring program that will work or some other method of getting this to work I would be very thankful. I'm posting a pic of my error to help clarifiy my situation.
I get almost the exact same error when I use multipass VBR files created with Cinemacraft. I just ignore it and the discs have always played fine afterwards...
well after a bit more tinkering I was able to use DVD shrink to get the video to about 3.8gbs then I could use a mp3 to ac3 converter and simply use the insert from DVD-Video option and replace the audio track with with my custom one and it worked
I got the same error but this time it was able to make the DVD anyway.
thanks for the responce mh2360
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 06:17 -
.m2v outputs from ffmpegX won't compile in DVD-SP 4 (internal muxer error)
By bbartley9 in forum ffmpegX general discussionReplies: 4Last Post: 21st Aug 2010, 03:57 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
How to reverse a M2V file
By lorix in forum EditingReplies: 2Last Post: 13th Nov 2008, 04:09 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08
