so i used ashampoo shrink n burn to get some videos to disc (dvd), although i didnt use there burning engine
so now ive got 3.99gb roughly of divx avi files that i want to get to dvd
the thing is though, im tryin in neros vision express and they dont fit, the files seem to get larger as i load them up?any idea how i can get these vids to dvd? theres numerous avis they dont exceed 4.7gb
The source avi file size does not matter. You are converting to another video format that requires higher file size to acheive similiar video quality. How many minutes are the avi divx video?
And try something else than NeroVision like ConvertXtoDVD or DVD Flick.
And please search, https://forum.videohelp.com/viewtopic.php?t=323519&highlight=wont+fit https://forum.videohelp.com/viewtopic.php?t=323372&highlight=wont+fit -
As a general (but not exact) rule, converting Divx/xvid encode material to DVD requires 3 - 4 times the bitrate (and therefore space) to maintain similar quality. So your 4GB of Divx/Xvid files realistically needs 3 - 4 (or more) DVD5s.
If you are willing to do the conversions manually then you can look at options like half-D1 resolution, which will allow you to use a lower bitrate, and so get more on a disc. But none of the one-click-wonders do this. -
thanks for the said info and links, i tried searching but didnt find anything sorry
আমি বাংলায় গান গাই
DVD Shrink and IMG Burn
By tcory in forum DVD & Blu-ray WritersReplies: 10Last Post: 9th Jan 2011, 15:25 -
Trying to burn a dvd using dvd shrink and Nero 10, please help a newbie?
By KtuluAlly in forum DVD RippingReplies: 6Last Post: 30th Dec 2010, 14:33 -
Error when dvd shrink trys to burn thru nero automatically
By themow in forum Video ConversionReplies: 1Last Post: 13th Oct 2007, 14:12 -
Any way to get DVD Shrink to burn faster then 2.5x?
By happydog500 in forum DVD RippingReplies: 1Last Post: 1st Oct 2007, 00:50 -
DVD Shrink/Nero burn errors
By chibimaru in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Jun 2007, 04:22
