I suddenly find that I can not convert AVI to MPEG using either MainConcept or TMPG XPress. Trying to use MainConcept, I get a message that says simply "Video Data Not Found." TMPG XPress says the same thing with more words - "The video part of the file could not be opened. Only the audio part can be opened."
What seems odd is that, while in the past I would ocassionally find such an AVI file, at this time every single AVI file that I download and every single AVI file already on my hard drive gives such a message.
I don't know if or how it could be related, but just a couple weeks ago, I had a hard drive failure. I replaced the hard drive and installed the operating system (XP Home) from scratch. It seems that this is when this problem began. I reinstalled MainConcept v1.4, and I bought and installed TMPG Video Encoder Xpress v. 3.1.5.81.
Is there anything I can do to convert these files? Is there possibly some setting that I've overlooked?
Any help will be appreciated.
You could also run your AVIs through GSpot for some clues.
http://www.headbands.com/gspot/
Convert from MKV to AVI (mpeg-4 codec) + add subtitle to the video file
By kovacic_10 in forum SubtitleReplies: 3Last Post: 19th Feb 2011, 18:38 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
Optimal L1 Data Zone Start LBA: None found! (VTS_04)
By thief_ in forum Authoring (DVD)Replies: 0Last Post: 28th Nov 2007, 01:05 -
Avi to DVD (mpeg2) in Mainconcept Mpeg Encoder, basic how to
By reboot in forum User guidesReplies: 31Last Post: 6th Aug 2007, 16:56
