I had already search in the forum, but i dindīt find anything that solves my problem!
My question is this:
I have for example multiple avi files (in xvid) and i want to create a menu in a DVD where i choose the button for the respective file.
This is to use in a DVD player that as the capacity to read xvid files.
Thank you very much
This could help:
https://www.videohelp.com/tools?tool=DivX_Author
RegardsThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety. (Benjamin Franklin). -
still, those program sugested are not what i need...there must be something more user friendly like autoplay menu builder but for DVDīs.
thank you -
No, there is not. Only Divx Ultra Certified players will playback Divx menus, and you have to use the above mentioned tools to create them. TDA is probably the easiest to date.
If you only have a standard divx/xvid player and Xvid files then you can only have the menu that the player gives you. That is how it is. Live with it.
Your other choice is to make a DVD instead.
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 09:07 -
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 14:29 -
DVD Menu with Chapter and Menu Template.
By big-boo in forum Authoring (DVD)Replies: 3Last Post: 17th Mar 2008, 06:20 -
dvd menu and sub menu program
By mikeoliver1313 in forum Authoring (DVD)Replies: 7Last Post: 20th Jan 2008, 11:31 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
