Hi,
I was trying to convert a Xvid file to xvid resized and lower resolution for PSP. But while saving VirtualDub gave me error "no audio decompressor could be found to decompress the source audio format". I have converted a lot of files for PSP with virtual dub but never got this error.
I am getting this error for one specific file..
Thanks.
Well - what audio format is in your source file? You're obviously lacking the audio codec VirtualDub needs.
If it's a format PSP can handle, just set audio to direct stream.
/Mats -
Just install AC3 ACM Decompressor.
Install this and you can convert/decompress AC3 audio directly to WAV/MP3 using Virtualdub, Tmpgenc, etc. AC3 encoding support in latest versions.
No audio decompressor could be found using VirtualDub
By dapster in forum Newbie / General discussionsReplies: 22Last Post: 6th Jun 2015, 05:25 -
VirtualDub - No audio decompressor could be found.
By kelemvor in forum Video ConversionReplies: 25Last Post: 24th Jan 2013, 17:36 -
Vorbis decompressor for virtualdub
By mkr10001 in forum AudioReplies: 2Last Post: 14th Mar 2012, 13:58 -
[solved] virtualdub + no decompressor prob...
By j6044 in forum EditingReplies: 18Last Post: 4th Sep 2010, 08:14 -
VirtualDub Error 'Says "Couldnt locate decompressor for format xvid"
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2010, 00:05
