Results 1 to 9 of 9
    Jan 2007
    Singapore
    hi, i'm suppose to reder a video that is not larger than 300x400 pixels.
    Also, there are suppose to be in AVI format and must use standard compression.
    What are the standard compression.
    What would you suggest i use?
    Apr 2004
    Miskatonic U
    There is no such thing as "standard compression"
    Can you put more context around the request ?
    Read my blog here.
    Jan 2007
    Singapore
    i was merely told to use a standard compression. i've no idea which compression it is.
    Dec 2004
    Australia
    Probably they mean compression that windows can natively handle. In other words something old and crap like cinepak.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Or mpeg1, it will work on most systems without needing to install anything.
    Dec 2004
    Australia
    mpeg-1 in avi? Does that usually work? I know it works with ffdshow to decode.
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    I missed the avi part . I guess it wont work that well for most.
    Jan 2007
    Singapore
    it's suppose to work both on windows and mac, and should not need any decoding to be viewed. is cinepak ok?
    Dec 2004
    Australia
    Should definitely work on Windows and Mac. It does require decoding just that the OS' should ship with the decoder.
