  1. The Mustang King arcorob's Avatar
    Dec 2001
    Seattle
    I hooked my DVD player (Pioneer DV-414) to my input on my ATI all in wonder capture card. I set the input to composite, press play, I get a beautiful picture.
    When I record, it still plays fine but the resulting file is a frozen screen of whatever I first started record. The very top of the screen (1/8 inch) seems to have the movie going by.
    Is this part of copy protection scheme or do I have a setup problem ?
    Thanks in advance....It is probably a newbie "Hey, you can't do that " question but I had to ask.
    Nov 2001
    Chihuahua, Mexico
    DVDs are copy protected by macrovision, is macrovision off on your DVD player ?
    for me that seems to be the problem, find out how to turn the macrovision off your DVD player or ATI card.
    ! Viva Mexico !
  3. i disable the thing in my apex player
    look in compatibility list to find firware for your player
    ( easy cd burning )
  4. go to best but get the Sima copy master it will fix your problem it goes for $50.00
  5. The Mustang King arcorob's Avatar
    Dec 2001
    Seattle
    On the web for as little as 39.99
    Question is...does it work ??? Anyone here own one ???
