I have a subtitle file that won't play in vlc player and I would like to convert it to a format that does, but I do not even know what format the file currently is. Below are the first few lines of the subtitle file. The current file extension is just a .txt
Thanks for your help
[1][30]movie info: XVID 624x448 23.976fps 127.3 MB|/..::SyNtEr::.. AQQ # 10101
[505][529]Honestly, we're out of gas.
[539][575]So, what are we going to do now?
[697][725]l'm sorry l didn't believe you.
[732][750]Could l ask you something?
[752][766]What?
Not sure, but have you tried to load it up in some subtitle editor/converter like Subtitle Workshop, to save it out as .srt?
/Mats -
Actually I had just finished that and was coming back to report that it worked.
Thanks.
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
