I'm converting a video .avi (xvid) on Total video convert to a mp4 file, but every time I got this error when I try do open on bsplayer after finished. Anyone know what it could be ?
What codec have you converted the file to? MP4 is just the name of the container, not the codec. AVI is also a container name but doesn't tell you much of anything about the type of video or the codec it's using. Try dropping it into Gspot 2.60 and see what it says. It should also tell you if you have the proper codec installed for playback.
And you might try VLC media player. If it works there, then you may just have a codec problem with playback. If not, then you might try a different encoder. SUPER is free and does a fair job.
vobblanker error "ifo has more than one pgc, not supported"
By patz in forum Authoring (DVD)Replies: 15Last Post: 26th Apr 2012, 01:58 -
AVStoDVD does not start... says "VB6 Common Controls not found!"
By granturissimus in forum Newbie / General discussionsReplies: 2Last Post: 12th Jan 2011, 07:15 -
How can I fix a "interface not supported" error in avi2dvd?
By Han Solo1 in forum Newbie / General discussionsReplies: 2Last Post: 19th Feb 2009, 14:51 -
philips dvp5992 displays "Video Resolution not Supported"
By mike69 in forum DVD & Blu-ray PlayersReplies: 20Last Post: 30th Dec 2008, 09:17 -
DVP5990 says "USB HUB NOT SUPPORTED"
By siratfus in forum DVD & Blu-ray PlayersReplies: 4Last Post: 29th Dec 2008, 23:43
