Im trying to add a video... so i add one and then i add one more and
then it says:
So then i get VideoReDo and redo the image but 4:3 - the same as the first one.. it still says its not allowed :S:S
Im also getting loads of other errors when i try to add others...
isn't there a setting where i can just allow anything?
i dont get whats going on
thanks for help
Ed
You can't mix 16:9 and 4:3 material in the same title (or in TDA parlance, Track). Obviously Redo hasn't changed the aspect ratio correctly. You can use ReStream to try again without re-encoding, however just changing the aspect ratio isn't the fix. This will just get you distorted images.
Basic rules
1. All assets in a title must have the same resolution, aspect ratio and format (PAL or NTSC).
2. All assets in a title must have the same audio properties on the same tracks.
3. Mixing formats (PAL and NTSC) is not DVD compliant. Some software will author it and give a warning. Some will refuse to author it at all.Read my blog here.
Should work if you add as seperate tracks, click "add new track" insead of "add file".
"Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by ZippyP.
TMPGEnc DVD Authoring Audio slowdown
By Namrepus221 in forum Authoring (DVD)Replies: 0Last Post: 11th Oct 2009, 02:25 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 21:15 -
[help] TMPGENC DVD AUTHORING v3 - unable to convert to MPG
By meeya in forum Authoring (DVD)Replies: 3Last Post: 19th Dec 2008, 04:47 -
Can't have more than 24 chapters on TMPGEnc DVD Authoring?
By aqualung2003 in forum Authoring (DVD)Replies: 19Last Post: 5th Jan 2008, 14:41 -
tmpgenc slow dvd authoring
By mystic818 in forum Authoring (DVD)Replies: 2Last Post: 20th Nov 2007, 05:21
