I use FitCD to solve an overscan problem. It all worked fine with .AVI files, but then the files switched to a format called Nero ShowTime Files. That's all it has for the file name. So, could somebody tell me what this file type is, and tell me how I can make it work in FitCD? Please?
Results 1 to 15 of 15
You installed Nero and it took ownership of all your video files.
The good news is that the files themselves haven't changed, just the file association.
Try this first : Open Windows Explorer (right-click My Computer and select Explore). Click on Tools -> Folder Options. Click on the View tab, and under Advanced Settings, untick "Hide extensions of known file types". Click OK.
You will now be able to see the three characters after the . in the file name. Note that the avi files are still avi files.Read my blog here.
Open FitCD. In the bottom half is the mpeg Resizing section. There is a button marked source, which is what you would normally use to load the source video. In your case, you are saying FitCD will not load it.
Next to this button are two fields for your resolution, and a drop down list for the aspect ratio. Put in your Width and Height, and set the AR. For most downloaded avi/mkv assorted crap it will be 1:1 Monitor.Read my blog here.
Need to supply "File Type" and "Mime Type" info for MKV file
By oneking in forum Newbie / General discussionsReplies: 9Last Post: 9th Feb 2012, 03:31 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 15:59 -
video file won't play. need to know what type it is - what codec?
By chriscaton in forum Video ConversionReplies: 7Last Post: 12th Jan 2010, 08:20 -
FitCD issue (audio won't sync)
By nwfn in forum Newbie / General discussionsReplies: 8Last Post: 9th Jun 2008, 13:03 -
Why won't my VTS_01 file work on windows movie maker?
By LITEONDVD in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2007, 10:13
