  1. Hi, I'm having trouble importing an M2V file into TMPGEnc 4.0 Express. I demuxed the audio and video from the DVD using input stream processing in DVD Decrypter. The resulting M2V file plays fine in WMP, PowerDVD, B's Player, etc. But when I import it into TMPGEnc for muxing with another audio file, it says the M2V file only has one frame.
    Any thoughts on why TMPGEnc won't read it properly? I'm using Win XP SP2 with 3gb of RAM.
    Thanks!
  2. That's a problem with the demux part of DVD Decrypter. Either try another demuxer (projectx, vobedit, pgcdemux, rejig...) or open the m2v file in mpeg2schnitt or cuttermaran and 'cut' the whole video. Maybe restream or VideoRedo can fix the stream too, but I've not tried it myself.
  3. Thanks for the advice. I haven't had any trouble with TMPGEnc reading any other M2V's I've demuxed using DVD Decrypter, but I'll try one of the other demuxers you suggested.
    Thanks again.
    Dec 2004
    Triptonia
    It sounds like a multi angle dvd
