Hi there,
I have a .mkv HD video. Now, I wish to convert the video to avi. The problem is i tried alot of ways with alot of proggies but it seems i can't get ahold of it.
I followed this guide:
https://forum.videohelp.com/viewtopic.php?t=241422
Installed the CCCP codecs from the matroska site. The guide mentioned up here, when opening in Virtual Dub it gives some errors, and as astreams it only gives the audio. I also tried mkvextractgui, it extract the audio track which is a .ac3 one, and gives some error about the video.
Now what i know is the video plays in vlc but it stutters abit, so i wish to convert to avi in order to play it in powerdvd using the purevideo feature for performance improvement.
I need some help or someone who has tried this before. Sorry if i posted this in the wrong section.
Cheers
Some mkv videos just wont open in Vdubmod..
Check out this guide..
https://forum.videohelp.com/viewtopic.php?t=268844
the mkv videos I couldn't get to work in vdubmod worked in here. -
I tried that method, the process seems to have gone fine. The problem is that WMP wont play the file, it just doesn't start. And powerdvd locks up as if trying to load the file, but doesn't load it at all.
Now that i tried merely every possible method, i wish to know if my PC can at least handle HD first thing.
My Setup:
P4 3GHz S478
1GB RAM
6600GT AGP
WD 320GB
Regards -
Are you sure you're using the latest version of MKVExtractGUI and the underlying mkvtoolnix?
If cameras add ten pounds, why would people want to eat them? -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Converting MKV to AVI (720p)
By shorto in forum Video ConversionReplies: 9Last Post: 24th Mar 2011, 06:41 -
Converting .mkv to .avi using AVIMuxGUI
By raphytaffy in forum Video ConversionReplies: 3Last Post: 16th Jun 2010, 22:46 -
By davidw89 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jun 2008, 11:38 -
In need of help with converting .mkv to .avi format
By nabeelnk1 in forum Newbie / General discussionsReplies: 2Last Post: 31st Dec 2007, 16:47
