I just bought a Storex MPiX-355 external HD which is also a Media center that allows you to directly connect the HD to a TV set and see Mpeg, avi, DivX, Xvid. The problem that I have is that I can't find how to see the subtitles in the divx movies that I have. Any ideas? The manual doesn't give any clue.
1.The manual says nothing about subtitles.
2. Device doesn't support UNICODE encoding so forget strange languages ...like greek.
3. FAT32 limits file size to 4GB
4. If you load lot of files to this device then AUTO-SEARCHING will last... for ever.
5. Stand-by button seems to be useless.
6. Support is in french ????
for this and other reasons, i will recommend just to check better if STOREX-355 is the product you really need. My opinion?.... keep away from STOREX!
thx, i still wait from STOREX to anwser to my questions, requests for support, statements....
Subtitle Problem
By cyberlion in forum SubtitleReplies: 19Last Post: 24th Jul 2010, 09:44 -
My new subtitle problem
By pensioner in forum Newbie / General discussionsReplies: 1Last Post: 7th May 2010, 03:32 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 22:16 -
Running Lines on Screen from Pioneer DV-355 DVD Player
By trini_davidg in forum DVD & Blu-ray PlayersReplies: 1Last Post: 8th Jan 2008, 11:36 -
a problem with subtitle
By matrix man in forum SubtitleReplies: 1Last Post: 15th May 2007, 13:36
