I spent a lot of time trying to figure out which resolutions were best for which aspect ratios when converting my DVDs to h.264 iPod video MP4 files
I made a little webpage, plus an excel file to handle the calculations if anyone else is needing help with this. To use the excel file: simply put in the Aspect Ratio of the DVD (if you don't know, you can usually look on the dvd or the case or google the movie title + "Aspect Ratio"), then enter a width (must be a multiple of 16 - a chart of multiples is included) - the excel file will automatically calculate the closest height for the given width and tell you which encoder to use (H.264 or MPEG) in Handbrake.
thanks to all the people on the VideoHelp and iPodLounge forums that helped me get this stuff straight
more info, plus the best settings are here:
http://cuestreetstudios.com/projects/video/
--bp
brandonjp%20-%20handbrake%20-%20dvd2ipod%20-%20aspect%20ratio%20guide.xls
Results 1 to 1 of 1
DVD > Ipod Classic > TV [Aspect Ratio]
By Will Hay in forum DVD RippingReplies: 13Last Post: 16th Jul 2012, 11:07 -
DVD > iPod Classic > TV - Aspect Ratio question
By Will Hay in forum Newbie / General discussionsReplies: 0Last Post: 18th Mar 2012, 04:05 -
Resolution vs Aspect Ratio
By triptych in forum Newbie / General discussionsReplies: 17Last Post: 7th Aug 2009, 07:23 -
Trying to change aspect ratio from 19:9 to 4:4 for mp4 iPod Docking System
By llee782 in forum MacReplies: 3Last Post: 22nd Jun 2009, 17:49 -
DVD to Ipod resolution & aspect ratio
By lemmy999 in forum Portable VideoReplies: 1Last Post: 18th Jul 2007, 13:47
