I'm learning how to use Nero Vision to back up full DVDs. This was recommended to me, because a few of the DVDs are PAL & I'd like to switch them to NTSC. Anyway, I've got the basic idea... however there's one BIG catch. I can't figure out how to keep all the menus and titles in sync like the original disc. I see that they all there, but on the final product they all play consecutively... there's no choosing chapters or scenes or even selecting from the menus... they all just play through to the next title or menu. Can this program give me a backup that plays THE SAME as the original? If not what programs will?
NeroVision is not for backing up DVD. Nero recode is. However Recode will not switch formats. PAL to NTSC is not trivial, and should be left up to a low quality program like NeroVision.
If you do want to change PAL to NTSC and keep everything (and have good quality as well) then you should read this guide : https://forum.videohelp.com/viewtopic.php?t=300144 through to the end (it refines itself along the way). You can apply this to pretty much any good mpeg-2 encoder. Try HCEnc - it's free and very good.Read my blog here.
Nero Vision xtra
By salohcin69 in forum Latest Video NewsReplies: 0Last Post: 20th Apr 2010, 05:30 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
Nero Vision 5 Help
By luckyboym in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2008, 00:47 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Vision 5
By marioval in forum Authoring (DVD)Replies: 0Last Post: 11th Oct 2007, 13:45
