Hi, everybody,
I am trying to mux with TDA an m2v with audio file (English language track) in order to create a DVD. TDA gives an error message: Cannot open the audio file: "Name" T01 1+1ch 32Kbps DELAY 0ms.ac3
The file shows a weird audio length of 21 minutes while the movie runs over 90 minutes but the file plays OK and audio is OK.
I tried to create wav from the English one with GoldWave but when I convert the wav to ac3, I get an audio file of a huge size. It is much bigger than the wav.
I tried to play the wav file but there is no audio.
When I was demuxing DVD with DGMPIndex, I've got two audio files - with the Engslish and Spanish languages. The Spanish one can be opened and shows the right length. It has different extension: "Name" T03 3_2ch 448Kbps DELAY 0ms.ac3
What could be wrong with the English audio track? Thank you!
Guys,
I realize that I've probably provided not sufficient information to get an advice on the issue.
I am ready to provide as much info as required. Just please advise me what other info is required.
Thnak you! -
guns1inger,
Thank you!
I will definitely try it and will post the result.
Audio problem while converting trp file
By ngr in forum Video ConversionReplies: 3Last Post: 13th Oct 2010, 14:22 -
some m2ts file audio problem
By alirafaat in forum Blu-ray RippingReplies: 2Last Post: 30th Apr 2009, 04:28 -
PMP file audio problem
By littlecramp in forum Software PlayingReplies: 0Last Post: 31st Dec 2008, 03:18 -
Problem with audio in .mkv file
By vertical in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2008, 18:26
