Hey
I have a burnt dvd with 5 clips of about 30 seconds. After each clip i want it to return to the menu, this doesn't happen, it just plays all 5 clips then returns
how can I return?
Im open to try new software.. i used nero to make my original menu..
thanks
Ed
Nero is not a great authoring tool. That said, I suspect that somewhere in th4e settings will be a tick box that will make the changes you require. You will have to experiment or, god forbid, read the help files to work out what needs to be changed. I would be looking for something along the lines of continuous playback or similar.
Read my blog here.
just looked around and cant find it
anyone know any decent software that will let me do this? -
Tmpgenc DVD author
GUIForDVDAuthor
Ulead
DVD Lab or Pro
Pretty much anything except, it appears, Nero. Even ConvertxtoDVD can do this.Read my blog here.
Originally Posted by ntscuser
where do i go and how do I make sure after the clip it returns to the menu. Im a bit confusedi have added the clip...
now what.. -
Create menu--->Menu display settings--->Action to take after each track has been played--->Display Main menu (or "Display Track menu", depending on Display menu settings)
How return to reference menu after adding a new audio track on a muxed DVD
By alvin68 in forum Authoring (DVD)Replies: 41Last Post: 20th Dec 2011, 12:26 -
Return to Title - NOT Chapter Menu - HOW?
By jlrm365 in forum Authoring (DVD)Replies: 7Last Post: 13th Mar 2010, 21:15 -
Play All and Return to Same menu Problem
By cassy in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2009, 19:14 -
Which menu to return to when a movie is finished?
By mmasroorali in forum Authoring (DVD)Replies: 3Last Post: 23rd Sep 2008, 08:53 -
DVD Lab Pro - Play Chapter and return to menu
By SCDVD in forum Authoring (DVD)Replies: 4Last Post: 5th Dec 2007, 16:05
