hi,
I've encoded a xvid progressive clip to mpeg2 with cce serving with avisynth.
I want the product image to be as the source image is. However the encoded image is slightly displaced upwards. i.e the bottom of the source frame is a few lines above the bottom of the final image. (I could post pictures i guess if needed)
I'm using essentially nothing in avisynth
I've not messed with much settings wise in cce.Code:AVISource("title.avi", false) Lanczos4Resize(720,480)
I've disabled dvd compliant and pulldown as I want a 23.976 mpeg2, that would be the major change.
help please
ty
edit: product image to be exactly the same as resized source image that is; to be clear.
It's perfectly clear.
I thought it only did something when you had interlaced source.
Then again I should have thought of it I guess.
I'll try it now -
Thanks.
I feel quite stupid having missed that. Especially as I reccently set offset to 0 when sampling a bottom field interlaced source. I also remember feeling that having offset default at 1 was stupid.
Videos sometimes has displaced color
By Monarch1st in forum Software PlayingReplies: 2Last Post: 17th Apr 2012, 20:42 -
Slightly disappointed?
By unabatedshagie in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Mar 2010, 10:43 -
x264 encoded mkv/mp4 transcode to xvid encoded avi
By graysky in forum Video ConversionReplies: 4Last Post: 9th Aug 2008, 18:55 -
Some DVD authoring programs will not accept CCE encoded mpeg2 files
By ettin in forum Authoring (DVD)Replies: 8Last Post: 18th Jun 2008, 14:57
