Results 1 to 9 of 9
    Feb 2007
    Hello all,
    Im using Nero Recode to select a few chapters to put on one DVD.
    They come from different DVDs
    I have copied the TS_VIDEO folders to the hard drive and when i try to "import titles" in Nero Recode by browsing to them, Nero shows the folders as EMPTY...
    They were shot with my Sony DVD 405 camera, and the files are there!
    Help appreciated,
    Thanks,
    mark.
  2. Member MysticE's Avatar
    Nov 2003
    When you Explore these DVDs you find the normal files in the VIDEO_TS folder?
    Feb 2007
    Hi there,
    Yes, I have all those normal DVD files in the VIDEO_TS folder... its very odd.
    When i get home i can do a screen grab of the contents to show exactly whats there.
    Thanks,
    Mark.
  4. Member MysticE's Avatar
    Nov 2003
    Do note that Recode imports the whole title, not individual chapters or VOBs. You would then use 'Start/End' to choose what you want to keep.
    Feb 2007
    Hi there MysticE,
    Thanks for the reply.
    Here is an example of what I mean, though most of my DVD's work, quite a few are shown as empty in Recode.
    Do you know if there is any competitive software which does the same job?
    Thanks mate,
    Mark.
  6. Member MysticE's Avatar
    Nov 2003
    It needs to be a playable DVD. I never have to go to the VIDEO_TS folder, simply clicking on the main folder opens the title. Is that a playable DVD or just a collection of files? It certainly looks odd.
    Feb 2007
    Hi there,
    Yes it plays in my dvd player... it is a dvd-rw disk which was finalised and unfinalised several times, which is why it has so many titles.
    Do you know of other software that has more options, for example to choose a CHAPTER instead of a TITLE?
    Much appreciated,
    Thanks,
    Mark.
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    DVD Shrink ? It is basically recode before Ahead employed the author to write Recode for them. Again though, you start with a title and trim down to chapters.
    Otherwise you might look at DVD decrypter in IFO mode to isolate a single chapter to work on.
    Read my blog here.
    Feb 2007
    DvdReMake !!!
    IT IS FANTASTIC,
    Exactlly what I wanted, and FAR more powerful than Recode.
    Whew.
    Thanks for the help guys,
    If anyone wants to join up to 4 DVD's into one, and keep the menus, this is the way to go.
    Mark
