  1. Hi all Im not sure how old the article but there is section where the person says say the bitrate slider as close to 1150 (1.15) as possible and Im not sure maybe in older version you couldnt but if you put your pointer on the butr,ate line you can click the numbers one by one hence you can set it directly at 1.15
    Jan 2002
    italy
    now you can set slider to 1.12. it' not possible write 1150
    bye
  3. http://www.vcdhelp.com/MMC_Reg_Tool.zip
    you can set it exactly to 1150
    there is a more advanced tool being worked on at
    http://stinky.dosrules.com
    -stinky
  4. What are you talking about Pm62 I just set it to 1.15 thats what my post just said so YES IT IS POSSIBLE TO SET IT TO 1.15
  5. ACTUALLY YES you right I was thinking I did it by putting pointer on bitrate line and clicking up But as I just tryed it to get it 1.15 you just use the left and right arrow keys to set the bitrate at 1.15 or what ever you desiered setting bitrate but no moving the slide bar wont let you set it at the 1.15 but the arrow keys will
