Well, I decided to make this a new topic since it is very specific. I am using RIPIT4Me and decrypter then dvdshrink to backup a dvd. I have tried this multiple times and keep getting an error after DVD shrink does its think stating Cannot correct TRF. Below is the complete body of the error. I have done everything to the letter of the RIPIT4ME guide and am still getting this error. Any thoughts?
1A22-0206-0530-1610-5715-1441*
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=0, 2, 1, 3, size=66560 bytes, created 8/25/1999 12:55:32 PM
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 11:54:32 AM
NT-SPTI used
Nero API version: 6.6.1.4
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 1, 4d
Recorder: <SONY DVD RW DRU-720A> Version: JY01 - HA 1 TA 1 - 6.6.1.4
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
=== Scsi-Device-Map ===
DiskPeripheral : ST360020A atapi Port 0 ID 0 DMA: On
DiskPeripheral : Maxtor 6Y080P0 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : DVD-ROM atapi Port 1 ID 0 DMA: On
CdRomPeripheral : SONY DVD RW DRU-720A atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
DVD-ROM E: CDRom0
SONY DVD RW DRU-720A F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1047984kB)
Free physical memory: 573MB (587664kB)
Memory in use : 43 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
25.2.2007
NeroAPI
12:59:52 PM #1 Phase 112 File APIProgress.cpp, Line 275
DVD-Video files reallocation started
12:59:52 PM #2 Phase 114 File APIProgress.cpp, Line 275
DVD-Video files reallocation completed (no file modified)
12:59:53 PM #3 Phase 111 File APIProgress.cpp, Line 275
DVD-Video files sorted
12:59:53 PM #4 NEROAPI 7 File Burncd.cpp, Line 3095
Error:\nCannot connect TRF.
12:59:53 PM #5 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
12:59:53 PM #6 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=5.3.5.10, size=23436 bytes, created 6/6/2003 5:12:57 PM
File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created 5/6/2002 10:01:08 AM
File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 7/27/2006 12:28:33 PM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Thanks mystice. I "burned" to my HD as audio and video folders then used nero to burn to a DVD from those files and it worked fine.
When did this stop working. Seems as if only last month or so I was having no issues. When did this nero part with shrink stop working?
Subtitle Creator error: Input string not in correct format
By kpic in forum SubtitleReplies: 6Last Post: 31st May 2013, 03:17 -
Avi index error in vdubmpeg2 - how to correct?
By yoda313 in forum Video ConversionReplies: 3Last Post: 15th Mar 2009, 20:44 -
Staxrip - says it can't find audio, chek my PID error - how do I correct it
By Emanef in forum DVD RippingReplies: 4Last Post: 24th Aug 2008, 12:21 -
Manually altering flag to correct aspect ratio error...
By Board Room in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th Aug 2008, 06:26 -
Usinf IFOEdit to correct an error in authoring
By netmask56 in forum Authoring (DVD)Replies: 3Last Post: 30th Nov 2007, 22:30
