Hello,
I'm trying to save ~40 Hi8 films in DivX format for PC and TV use.
Before launching the whole process, I'd like to validate that the setup I use is the optimal one:
I acquire the DV thru Windows Movie Maker (WWM) (via a second DV camcorder), then I review the film, remove the unwanted parts. I then create a 'table of content' jpg file that I use as title inserted with WMM (WMM native titles are not convenient). I then recreate the DV based on these changes (cuts + title addition). I finally do the DivX encoding thru DrDivX OSS using High Definition and quality = extreme. This process is quite long and I'd like to make sure I do right before replicating 40 times...
Any comments/recommendation welcome.
Thanks in advance, Jean-Pierre
I have done something similar ( not so elaborate with the menus )
but i use 'DVD express' from 'ADS' tech for the capture , as it has real time hardware encoding to mpeg2 at very high quality settings, I then archive the mpeg2 files and use them to create DVDs,
but they could have processed to create AVIs or mp4's using Dvix
DVDxpress comes with is own capture software and Uleads 'movie factory' which IMO is superior to WMM, though I also have used it and started out with that program
there are now 2 or 3 versions of the DVDexpress hardware available, my version 2 years old is now available for about $49 -
My Panasonic e500 dvd recorder records to mpg4 with several quality settings. That's one way to do it.
Saving/capture solutions for saving off (extending) DVR
By ET3D in forum Newbie / General discussionsReplies: 1Last Post: 28th Oct 2011, 19:13 -
How to merge 2 films into 1
By Kypduron1 in forum Authoring (DVD)Replies: 8Last Post: 10th Aug 2010, 19:35 -
Sony Hi8 has been defective but want to play the Hi8 tape
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 22nd May 2009, 23:06 -
Hi8 vcr, better playback than a Hi8 camcorder?
By Knightmessenger in forum Capturing and VCRReplies: 8Last Post: 22nd Dec 2007, 02:11 -
Will cheap new Hi8 camcorder output better than old, worn Hi8 camcorder?
By ErikL7 in forum RestorationReplies: 7Last Post: 2nd Sep 2007, 07:26
