Hi.
I've just joined a site that lets you play their music.
When i click on the music icon i get.
You need to upgrade your Flash Player
I'll be totally honest, i'm a newbie in regards to all this, i have Adobe Flash Player 9
on my computer.
Can anyone tell me about solving this problem
Thanks for your time
Typically when you get that screen, there is a link / button to press to access the update. I've had this happen a few times recently, and for me it appears to only happen when there actually isn't an active broadcast...I can't explain why.
You could try deleting the temp files and cookies in your browser, close all instances of the browser, then reopen it and try again. Or try uninstalling the flash player, reboot, and reinstall the latest version. If all else fails, contact the website for help.Google is your Friend -
in addition - it might be the version or type of browser you are using
I get this on some sites and not others. I suspect the Nortoon Personall Firewall settings, or my IE security settings are blocking certain sites traffic. Hasn;t been enough of a problem for me to track it down.
.flv file: No duration with QuickTime Player or a Flash player
By french-petzouille in forum ffmpegX general discussionReplies: 2Last Post: 3rd Mar 2012, 12:00 -
DVP5992/37 will not power after flash upgrade
By awill99 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 20th Feb 2010, 11:41 -
Problem with my flash player
By freestyler9 in forum ComputerReplies: 1Last Post: 3rd Sep 2009, 07:21 -
PSP and Flash Player
By snafubaby in forum Portable VideoReplies: 0Last Post: 22nd Feb 2008, 19:29 -
Flash player 9
By ray316 in forum Software PlayingReplies: 5Last Post: 2nd Oct 2007, 18:28
