    Feb 2007
    France
    hello
    i'm a mac user et have no problem to convert video_ts to avi but now i'd like to convert to DVD.
    i've a video_ts of 7 Go i'd like to convert to 4,7 go DVD but when i put "encode" ffmpeg told me "active automatically mplayer encode to convert video_ts" and then the process appears but nothing is processing at all
    thx for your help ++
    Feb 2007
    France
    here is the process
    Encoding started on Sun Feb 25 14:03:44 CET 2007
    /Users/vincentpaire/Download/Queen .-. Live at Wembley/Queen - Live at Wembley 12-07-1986/movie/
    : File exists
    mkdir: .-.: File exists
    mkdir: Live: File exists
    mkdir: at: File exists
    mkdir: Wembley/Queen: File exists
    mkdir: -: File exists
    mkdir: Wembley: File exists
    mkdir: 12-07-1986: No such file or directory
    rm: /Users/vincentpaire/Download/Queen: is a directory
    rm: Wembley/Queen: Not a directory
    mkfifo: /Users/vincentpaire/Download/Queen: File exists
    -f 5 -b 6083 -q 3 -B 260 -V 230 -a 2
    mkfifo: Wembley/Queen: No such file or directory
    mkfifo: Live: File exists
    mkfifo: at: File exists
    mkfifo: 12-07-1986/movie//stream.yuv: No such file or directory
    /Applications/ffmpegX.app//Contents/Resources/mencvcdX: line 205: /Users/vincentpaire/Download/Queen .-. Live at Wembley/Queen - Live at Wembley 12-07-1986/movie//stream.yuv: No such file or directory
    -F 3
    /Applications/ffmpegX.app//Contents/Resources/mencvcdX: line 207: /Library/Application Support/ffmpegX/mpeg2enc: Malformed Mach-o file
    INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
    INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
    INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
    **ERROR: [yuvscaler] Could'nt read YUV4MPEG header!
    FIXME:Hardenabling SSE and SSE2 without detection
    MPlayer dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team
    libdvdread: Couldn't find device name.
    Mac OSX static build for ffmpegX
    CPU: Intel (Family: 6, Stepping: 6)
    CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
    Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
    get_path('codecs.conf') -> '/Users/vincentpaire/.mplayer/codecs.conf'
    Reading /Users/vincentpaire/.mplayer/codecs.conf: Can't open '/Users/vincentpaire/.mplayer/codecs.conf': No such file or directory
    Reading /usr/local/etc/mplayer/codecs.conf: Can't open '/usr/local/etc/mplayer/codecs.conf': No such file or directory
    Using built-in default codecs.conf.
    CommandLine: '-noframedrop' '-vo' 'yuv4mpeg' '-ao' 'pcm:waveheader' '-v' '-osdlevel' '0' 'dvd://1' '-dvd-device' '/Users/vincentpaire/Download/Queen' '.-.' 'Live' 'at' 'Wembley/Queen' '-' 'Live' 'at' 'Wembley' '12-07-1986/VIDEO_TS' '-dvdangle' '1' '-aid' '160' '-chapter' '1-28'
    get_path('font/font.desc') -> '/Users/vincentpaire/.mplayer/font/font.desc'
    font: can't open file: /Users/vincentpaire/.mplayer/font/font.desc
    Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
    Using MMX (with tiny bit MMX2) Optimized OnScreenDisplay
    Using Darwin accurate timing
    Terminal type `unknown' is not defined.
    get_path('input.conf') -> '/Users/vincentpaire/.mplayer/input.conf'
    Parsing input config file /Users/vincentpaire/.mplayer/input.conf
    Input config file /Users/vincentpaire/.mplayer/input.conf parsed: 2 binds
    get_path('1.conf') -> '/Users/vincentpaire/.mplayer/1.conf'
    Playing dvd://1.
    get_path('sub/') -> '/Users/vincentpaire/.mplayer/sub/'
    URL: dvd://1
    Reading disc structure, please wait...
    There are 1 titles on this DVD.
    There are 22 chapters in this DVD title.
    There are 1 angles in this DVD title.
    DVD successfully opened.
    [open] audio stream: 0 audio format: lpcm (stereo) language: en aid: 160
    [open] number of audio channels on disk: 1.
    [open] number of subtitles on disk: 0
    DVD start cell: 0 pack: 0x0-0x13C52
    DVD start=0 end=2208017
    STREAM: [null] dvd://1
    STREAM: Description: DVD stream
    STREAM: Author:
    STREAM: Comment:
    DVD Seek! lba=0x0 cell=0 packs: 0x0-0x13C52
    Angle-seek synced by cell/vob IDN search!
    Checking for YUV4MPEG2
    ASF_check: not ASF guid!
    Checking for NuppelVideo
    Checking for REAL
    Checking for SMJPEG
    Searching demuxer type for filename dvd://1 ext: (null)
    Checking for Nullsoft Streaming Video
    Checking for MOV
    Checking for VIVO
    header block 1 size: 0
    Checking for PVA
    Checking for MPEG-TS...
    TRIED UP TO POSITION 69412, FOUND 47, packet_size= 0, SEEMS A TS? 0
    DVD Seek! lba=0x21 cell=0 packs: 0x0-0x13C52
    Checking for LMLM4 Stream Format
    Invalid packet in LMLM4 stream: ch=0 size=1140851708
    LMLM4 Stream Format not found
    system stream synced at 0xD (13)!
    ==> Found video stream: 0
    DVD Seek! lba=0x10D80E cell=11 packs: 0x105650-0x11C39A
    ==> Found audio stream: 160
    DVD Seek! lba=0x21B01C cell=21 packs: 0x21076D-0x21B111
    --- END OF CELL !!! ---
    MPEG Stream reached EOF
    ds_fill_buffer: EOF reached (stream: video)
    MPEG-PS file format detected.
    Searching for sequence header... OK!
    VIDEO: MPEG2 720x480 (aspect 2) 29.970 fps 8264.0 kbps (1033.0 kbyte/s)
    [V] filefmt:2 fourcc:0x10000002 size:720x480 fps:29.97 ftime:=0.0334
    The selected video_out device is incompatible with this codec.
    Try adding the scale filter, e.g. -vf spp,scale instead of -vf spp.
    h('default.sub') -> '/Users/vincentpaire/.mplayer/default.sub'
    Opening audio decoder: [dvdpcm] Uncompressed DVD/VOB LPCM audio decoder
    dec_audio: Allocating 2048 + 65536 = 67584 bytes for output buffer.
    AUDIO: 48000 Hz, 2 ch, s16be, 1536.0 kbit/100.00% (ratio: 192000->192000)
    Selected audio codec: [dvdpcm] afm: dvdpcm (Uncompressed DVD/VOB LPCM)
    Using (default) progressive frame mode.============================================= =============================
    Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
    VDec: vo config request - 720 x 480 (preferred colorspace: Mpeg PES)
    Trying filter chain: vo
    Could not find matching colorspace - retrying with -vf scale...
    Opening video filter: [scale]
    SwScale params: -1 x -1 (-1=no scaling)
    Trying filter chain: scale vo
    VDecoder init failed
    Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
    Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2))
    Building audio filter chain for 48000Hz/2ch/s16be -> 0Hz/0ch/??...
    [libaf] Adding filter dummy
    [dummy] Was reinitialized: 48000Hz/2ch/s16be
    [AO PCM] File: audiodump.wav (WAVE)
    PCM: Samplerate: 48000Hz Channels: Stereo Format s16le
    [AO PCM] Info: Faster dumping is achieved with -vc null -vo null
    [AO PCM] Info: To write WAVE files use -ao pcm:waveheader (default).
    AO: [pcm] 48000Hz 2ch s16le (2 bytes per sample)
    AO: Description: RAW PCM/WAVE file writer audio output
    AO: Author: Atmosfear
    Building audio filter chain for 48000Hz/2ch/s16be -> 48000Hz/2ch/s16le...
    [libaf] Adding filter format
    [format] Changing sample format from big-endian 16-bit signed int to little-endian 16-bit signed int
    [format] Accelerated endianess conversion only
    Starting playback...
    [libaf] Reallocating memory in module format, old len = 0, new len = 65540
    VDec: vo config request - 720 x 480 (preferred colorspace: Planar YV12)
    VDec: using Planar YV12 as output csp (no 0)
    Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
    VO Config (720x480->720x540,flags=0,'MPlayer',0x32315659)
    VO: [yuv4mpeg] 720x480 => 720x540 Planar YV12
    VO: Description: yuv4mpeg output for mjpegtools
    VO: Author: Robert Kesterson <robertk@robertk.com>
    *** [vo] Allocating mp_image_t, 720x480x12bpp YUV planar, 518400 bytes
    Feb 2007
    France
    i've found the options "use mplayer decode" but it says "remove all special signs from the name of your files" ... don't know what to do, all my files are without specials signs???
    Aug 2005
    Palo Alto, California USA
    A space is an example of a "special sign." Get rid of those.
    In general, Unix is a bit fussy about things like that. To minimize hassles, stick to pure alphanumeric characters only. Not all apps are that fussy, but if you follow this rule, you won't get these kinds of messages.
    Feb 2007
    France
    thx but after removing all _ and space, ffmpeg doesn't recognize my files as video files anymore.... arghhhh !
    my files are a folder named video_ts and inside some VTS_01_1.vob and video_ts.bup and something like that.
    i really dont know what to do, i've try to convert those files in .avi = no problem and all files can be opened there are no corrupt
    please help me i really would like to make this DVD
    thx ++
    Aug 2005
    Oh, sorry for not giving you more complete information. Don't change the name of any files inside the dvd folder, only those outside. You should assume that the dvd folder itself is properly authored, which includes properly named and arranged pieces.The underscore is a legitimate (and necessary) character. So, change your VIDEOTS back to VIDEO_TS, for example, and you should have better results.
    Again, you only need to watch out for special characters in the pathnames outside of the dvd folder itself.
