My LG GSA-4160B can't burn or erase rewriteable CDs or DVDs.
It says illegal media.
It burns the R discs fine.
I attached the log file from Nero.
It used to work, the problem started a few weeks ago.
Anyone could help, please?
log.txt
Has firmware been updated? Firmware updates often fix media related problems.
Has this media worked for you before?
The error log is consistant with media incompatibility.
The reports in the media list are mixed also suggesting media incompatibility.
This being an LG drive of some age there is a possibility of needing cleaning or lubrication. -
It's hard to find many burners that do well with 6x DVD-RW. Using an older burner like the 4160 with a max of 4x CLV for dvd-rw only increases the likelyhood of failure. If you've used these with success before then the suggestions for cleaning/lubrication would be in order - otherwise try a 2x or 4x dvd-rw. Good luck.
I've noticed that when I format my RWs, I can't record on them, so I no longer do it. It works. Hope this helps.
I tried cleaning the drive with a cleaner-disc but it didn't help.
The problem occurs not only when i try to burn 6x but with 2x and 4x too. And I used to burn them before.
Btw thanks for the suggestions.
Other ideas? -
What media is it really? 6x -RW?
Does your drive support such media???*** Now that you have read me, do some other things. ***
How do you burn initialized DVD discs?
By Djard in forum MediaReplies: 6Last Post: 24th Jul 2011, 13:26 -
Possible to burn AVCHD to multiple discs?
By hiimbored in forum Authoring (Blu-ray)Replies: 4Last Post: 2nd Jan 2011, 18:55 -
Should I burn 16x discs at 8x?
By sky captain in forum Authoring (DVD)Replies: 22Last Post: 19th Dec 2007, 22:58 -
Can't burn DVD+R DL Discs
By RushMaster in forum DVD & Blu-ray WritersReplies: 7Last Post: 7th Nov 2007, 09:17 -
pioneer 510H will burn but won't read unfinalized discs
By nixie in forum DVD & Blu-ray RecordersReplies: 10Last Post: 6th Jun 2007, 19:25
