hello guys .... is there any way to find out whether the DVD Player and TV is NTSC or PAL ..
coz im currently buying new TV and DVD Player together ..
and 1 more question .. is computer able to play both NTSC and PAL mode ? @.@ thx
I'd imagine looking in the specs or the manual would be a good place to start. Having said that it is most likely whatever the local format is, lastly from my understanding most PAL DVD players will play NTSC discs.Originally Posted by GundamSeedW
Yes, it's irrelevant on a computer.and 1 more question .. is computer able to play both NTSC and PAL mode ? @.@ thx -
Don't forget region coding. For a DVD player you want one that can be set regionfree.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
