Hi, does anyone know if Adobe Encore DVD 1.5 can author DVD that is higher than 720x480? I have a HDTV and would like to view the DVD in widescreen mode and in HD. I have created an avi files from high resolution stills (6Mpix) in Adobe premiere pro 1.5 using 1080i settings. But I couldn't import the avi file in Encore because it's not 720x480. Is there a way to do it in Encore 1.5? If not, is Encore DVD 2.0 capable of doing that? If not, what other software would allow me to do that? Thank you in advance.
...ViEd
DVD authoring software only allows for authoring to DVD compliance. The maximum resolution for DVD is 720 x 490 (NTSC) or 720 x 576 (PAL). If you want to author a DVD, you have to meet these specs.
If you want to author in HD resolutions (1080i, for example) then you need to look at HD-DVD or BluRay authoring tools. However these will not play in a standard DVD player.Read my blog here.
Thanks gus1inger. But, what about the regular movie DVDs that can be viewed in widescreen and 1080i? They play on the normal DVD players, and don't need HD-DVD, isn't it?
Thanks. I just find that some of my highres(2816x2112) stills in my slideshow DVD were not all that clear. I used the same DVD player that played the normal movie DVDs, so if the player did the upconvert, then it should've upconverted the slideshow as well.
I also find it odd that Adobe premiere provided a HDV plugin in Premiere Pro 1.5 to create 1080i projects, but does not allow Encore DVD to author a 1080i DVD project. Oh well, I guess it's just the way it is. Thanks. -
Your hires stills were reduced to 720x480 on the DVD (that's the highest resolution allowable for NTSC DVD). No upscaling player will ever restore any of the detail that was lost. At best the 720x480 image will be sharpened a bit when upscaled.Originally Posted by ViEd
Maybe that's why it's called Encore DVD, not Encore HD DVD!Originally Posted by ViEd -
Thank you all for the information. As a newbie, I think this forum is great! Thx.
Want to rip from interlaced DVD's in highest/same quality!
By DARkTYranno in forum DVD RippingReplies: 17Last Post: 22nd Feb 2012, 16:05 -
Highest Quality XVID to DVD
By Merkaba188 in forum Video ConversionReplies: 10Last Post: 1st Jan 2009, 21:58 -
DVD to H264 - Highest Quality - Which is the best software to use?
By fgtan in forum DVD RippingReplies: 4Last Post: 29th Nov 2007, 08:37 -
How to get the Highest Quality from DVD -> xVid or whatever is better?
By mistafro in forum ffmpegX general discussionReplies: 10Last Post: 22nd Aug 2007, 13:25 -
Highest Quality DVD+R DL Printable discs?
By Cyrax9 in forum MediaReplies: 3Last Post: 17th Jun 2007, 22:15
