Hello!
Apologies if this specific issue has been covered elsewhere, I've tried using the search function and browsed the last 10 pages or so, but can't find anything on this topic in particular, only to do with .avi-DVD format syncing problems. =(
Anyway! My issue is as follows:
I'm trying to burn a DVD backup from a .img file I've created on my hard drive. The img file works perfectly when played through my PC on a virtual drive, but when I burn it (using Nero 7), the sound is always around 2 seconds out of sync with the video.
I am using (to the best of my knowledge) pretty good quality Verbatim DVD-R's, and i've tried burning on different speed settings but to no avail. The burner I am using is pretty new, and I haven't had these sorts of problems in the past. Any idea what I can do to remedy the issue?
Thanks!
Does the dvd play out of sync on your PC?
"Art is making something out of nothing and selling it." - Frank Zappa -
Ah, my apologies!
Yes, it seems that the DVD works fine on my PC's DVD drives. Perhaps I should have done a little prior research!
So does that mean that the issue lies with my home DVD player?
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
Ripping with SHRINK then BURNING with IMG burn
By efiste2 in forum DVD RippingReplies: 10Last Post: 17th Apr 2010, 00:39 -
Burning .IMG Files to DVD
By niteghost in forum Newbie / General discussionsReplies: 6Last Post: 3rd Dec 2008, 18:13 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19 -
IMG file, no sound??
By newtonnjd in forum Newbie / General discussionsReplies: 7Last Post: 14th Jun 2007, 18:56
