I tried using Microsoft Video Maker, but is there a better utility to capture the video through.
I don't have a firewire port on my computer to do direct capture with say WinDV...
Must I really buy a firewire card to get a decent transfer of video and sound?
I tried searching but all I got was info on capturing with an AIW card and I don't have the ATI MMC software and the MMC software that you can download is not compatible with my card.
What would you suggest?
Your card is an AIW but without the TV tuner so MMC intended for the X850 based AIW should work with yours.
But, if you intend transferring from a DV source, buy yourself a Firewire card. The quality you will get with a direct digital copy from camcorder tape to hard drive is going to be far better than doing a software conversion from analogue to digital and back to analogue again.
Video goes to snow with ATI Theater 650 pro capturing through s-video
By Des in forum Capturing and VCRReplies: 5Last Post: 26th Aug 2010, 08:37 -
Which Hard Drives/setup are best for capturing video/video editing?
By Balefor in forum Capturing and VCRReplies: 4Last Post: 29th Mar 2008, 14:24 -
Finding vivo on the newer video cards
By Steen4 in forum Capturing and VCRReplies: 6Last Post: 12th Nov 2007, 00:56 -
Capturing VHS by using VIVO
By Filsps in forum Capturing and VCRReplies: 0Last Post: 15th Sep 2007, 15:17 -
Lip sync on video captures using VIVO card
By Confused Chimp in forum Newbie / General discussionsReplies: 1Last Post: 7th Jul 2007, 19:36
