Hi guys
I just need a little advice on this matter i have checked the FAQ and dowloaded a few application namely Riva Flv, DVDx & Flash 8 player. I also have Flash 8.
I have ripped my DVD using Dvd decrypter, not that it was or needed decrypting. I now have 8 Vob files which are all short videos ranging from between 2mins to 8 mins in lenght. I realise obviously i need to convert the Vob files but don't seem to be able to do that with DVDx i can see all my files with DVDx and play them, but it doesn't seem to convert them. Therefore can someone please point me in the direction of a tutorial that will take me through the conversion part. I've read that flash 8 uses ON2 VP6 but i can find any information on how to convert to this format
Also i would like to upload all of these 8 videos which totals 2.5 GB can some give some idea of how playing these will affect my bandwith
any help greatly appreciated
Murphy was an Optomist
You can convert the vobs directly to flv with super or riva flv encoder. But they aren't using on2 vp6, try then Flash Proffesional(it comes with a converter) or On2 Flix. I'm not sure if they supports vobs directly, you can try or try use vob2mpg.
Or upload to youtube or google video and put on your website.
https://www.videohelp.com/guides.php?guideid=951#951 (super and riva guide) -
Many Thanks for the reply baldrick
i have now managed to sort out the short films which i have in two formats MPEG2 & MP4. With the MP4 format i can play them with Quicktime and the quality is brilliant I would therefore like to use the MP4 format, but i have included several thumbnail pics. What i'd like to happen is once a person clicks on the thumbnail the relevant video plays. I've tried linking to the file, but this just starts a download. Do I need to code it in order to get it to work. if so is there any tutorials i can follow
Many Thanks in AdvanceMurphy was an Optomist -
this is how you do it - though it depends on what type of file you are going to embed/stream ..... lots of encoders can do the coding for you (like on2 flix pro or QT pro)
let me explain the above codeCode:[img]picture path[/img]
src="picture path" -> it's where the your image will show in the place BEFORE the movie is loaded
border="0" -> picture border size
dynsrc="video path" -> put your real video path here
start="fileopen" -> this means the video will start to play when the file is open
loopdelay="10" -> how long you want the video to be delayed between the previous play and next play
loop="2" -> how many times you want the video to be played
OPTIONAL:
start="fileopen" -> another option is use "mouseover" to replace "fileopen", so, when you mouse over the image, the video will start to play!
loop="2" -> change 2 to "infinite" will allow the video to play on forever
NOTE:
1. If your use (start="fileopen"), then you probably don't need (src="picture path"), because the video play right away after it's loaded, if you use (start="mouseover"), then you DO need that, the image will load first, until you mouse over the image will the movie start to play!
2. If you use (loop="1), then you won't need loopdelay="10", because there is no 2nd play, therefore the delay between each play is not important!"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
appears that code is only for IE
your visitors will be stuck on one page waiting for the dl
I'd pop a window so they can at least navigate while waiting
you probably want some controls for a player?
PS - I want to see brilliant because I'm used to stunning... -
yea - i was real basic ... a quick google search will show a lot more coding (and prob a lot better) --
Video web page menu generation software?
By villaVideo in forum Newbie / General discussionsReplies: 5Last Post: 12th Jan 2012, 22:59 -
web page translator and email full page translator
By juststarting in forum ComputerReplies: 3Last Post: 1st Feb 2010, 10:23 -
embed video in a web page
By shashgo in forum Newbie / General discussionsReplies: 1Last Post: 13th Nov 2008, 21:26 -
embed streaming video on a web page.
By greendesert in forum Video Streaming DownloadingReplies: 1Last Post: 6th Sep 2008, 10:59 -
Web page to run from CD help.
By Poppa_Meth in forum ComputerReplies: 4Last Post: 26th Mar 2008, 11:51
