  1. Dear Forum
    I was trying to create a dvd using the above software, and using some files I had recorded from tv (dvb) and joined together using videoredo
    When processing the file the software threw up the following message:
    " your file has some open GOPs" and this might affect the final result.
    Please do anyone know what GOP's are and whether I need to "close " them and if so how to do it.
    Your kind help in this would be appreciated
    Ian
    ian c
    ttp://forum.videohelp.com/viewtopic.php?t=299930&highlight=open+gops
  3. Hi thank you however I click on the link and no reply occurs.
    If you can help I would be grateful
    Ian
    ian c
    Apr 2004
    Miskatonic U
    GOPs - Group Of Pictures. It is to do with the way mpeg compression works. Leaving GOPs open when encoding can give you slightly better compression. Open GOPS are perfectly legal in video encoded for DVD.
    DLP gives you a warning regarding open GOPS because it can affect the accuracy of chapter placement. However it is just a warning. If you are using DLP 1.6 or 2.x you can turn this warning off.
    Of you can look at your VideoRedo settings to make sure that it always uses closed GOPs when it does any re-encoding. I would suggest that it has done some minor re-encoding at the join points, an left the GOPs open.
    Me - I encode with open GOPs all the time, and author in DLP. I just turn the warning off.
    Read my blog here.
  5. Hi "Gunslinger"
    Thank you for this kind reassurance. I am very much a novice and havent touched chapters yet.
    Thank you again
    Ian
    ian c
  6. Member GeorgeW's Avatar
    Feb 2005
    Ian
    If you do want to see the link that Baldrick posted, add an "h" before the ttp://
    Regards,
    George
  7. Dear George
    Silly me
    Thanks for that - done it
    Ian
    ian c
