  1. Member AlecWest's Avatar
    Mar 2002
    Vader, WA, USA
    I have a still-shot menu I'm using on a DVD, allowing people to choose from one of two programs. There's about a 2 minute audio part to it that plays. However, when the audio completes, the video presentation goes partly out of focus until a menu choice is made. Is there an XML trick to replay the menu (and audio) if it completes prior to a choice being made?
  2. Free Flying Soul liquid217's Avatar
    Feb 2002
    click on the 'menu timeout options' button on the menu editor. It looks like a small timer. Tell it to simply loop the current menu.
  3. Member AlecWest's Avatar
    Mar 2002
    Vader, WA, USA
    Worked great, thanks. BTW, is there any way to reset the forced one second (minimum) pause to zero seconds? When it reaches the end of the audio, the video blurs for 1 second until the menu restarts itself.
  4. Free Flying Soul liquid217's Avatar
    Feb 2002
    In my tests, I have found that at 0 seconds, the DVD does not work correctly. You can always bypass it in the XML, but it will be up to your dvd player to play it correctly.
