  1. I try to load a d2v file, but it says it cant. What am I doing wrong?
  2. please put more details on your post so we can hlelp you beter
  3. Originally Posted by pinoy2201
    ok. I am following Sefy's guide to making VCD's. Im at the encoding process. I am using, as i said, TMPGEnc, vers 2.02 i believe. I go to browse, and the guide says to select the d2v file to encode. I have to select all files to see the d2v file. I click it, it says file is not supported.
  4. well did you install the vfapi plugin did you copy the DVD2avi.vfp to TMPGenc's folder???? if you didnt that miht be your problem
  5. i got the vfapi thing installed, and its checked in option drop down menu.
    Dec 2001
    Sydney, Australia
    I had the same problem, but I found that if you follow Sefy's guide it doesn't work. I got it to work by following Sefy's guide but not changing ANY of Sefy's options in SmartRipper. Follow all the other programs in the guide but just leave SmartRipper's options the way they are.
    That's if you're using SmartRipper?
  7. nope, i gots it. U have to load the dvd2avi file into the dvd2avi file dir, run it, and TMPGEnc.
