Okay i'm new to this but i have just got a DVD player and it does plays VCD/SVCD/XVCD/XSVCD. i also have a load of MOV files that i would like to put on VCD any ides what program i should use coz i have no idea, oh and don't say TMPGEnc it does not work even with the mov plugin that is in the tools section.
Thanks in advance for your help!![]()
TMPEGenc works for me.....Use the mov plug-in and up the priority (I believe you do this in the Environmental Settings). The only glitch I had was it seems to freeze at 100%, it encodes fine just won't let you close the prog unless you Task Manager:End Task. Good luck if this doesn't work.
Mark -
open your MOV in quicktime and export as an AVI... no there is nothing you cant do!
later bater. deltaboy
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 12:22 -
Mov conversion help?
By Timbo78 in forum Video ConversionReplies: 2Last Post: 13th Sep 2010, 07:10 -
MOV file conversion
By pidasms in forum Video ConversionReplies: 6Last Post: 13th Dec 2009, 16:42 -
.mov to dvd conversion
By tomm2000 in forum Video ConversionReplies: 1Last Post: 7th Sep 2007, 17:23 -
.mov to DV conversion
By aaron_rip in forum ffmpegX general discussionReplies: 4Last Post: 3rd Jul 2007, 17:55
