Hi, I have a free DVD i downloaded and the folder VIDEO_TS is filled with .VOB, .IFO, and .BUP
Anyway, When I open the menu .VOB file in VLC, I am unable to click on any of the menu options like Play , Bonus, etc...
When I open the other .VOB files they are various parts from the DVD...
How can I connect all the files to the dvd menu .vob file? Or any other ideas?
Results 1 to 14 of 14
Try something else then (even Windows Media Player can play DVDs if the required mpeg2 decoder is installed). IFO files are information files, it is the data in the IFO that tells which VOB should be shown and in what order.
VLC will not play the .vob file in the same way that a software DVD player would.Neither will WMP or MPC
It is used to play the raw video/audio part of the file and does not "react" to the "menu" etc commands contained within.**
To have the "menu" options etc work correctly you MUST use a player such as PowerDVD et al.
**(Can the old-timers now come in with the correct technical terminology please)Don't worry.......we'll be alright... -
As JonnyCabs has pointed out, you need a DVD player and not a Media player to get full menu functionality. A Media player will just play the video stream contained within the VOB files, a DVD Player will respond to the menu commands within the IFO files.
Why not burn it to a disc and put it in a settop player? -
Thanks a ton. I never knew you could do that. ^
If you use the above method, it will play the entire DVD and act as one continuous file, whether or not there are multiple VOB files as part of a series. It will also let you use the menu, choose what you want to play, *and* skip chapters forward and backward, and go to the menu whenever you want. I never knew VLC could do those things. Like the other posters said, I thought you had to use a standard DVD software program. Also, if you choose a specific chapter, you can still scroll forwards and backwards, because VLC treats the entire DVD as one continuous file, instead of being split up into shorter VOB parts.
The reason I like using VLC for DVD's now, a program I normally don't like, is because all standard DVD programs freeze on my computer, some programs more than others, but it always happens eventually. It doesn't matter if it's Power DVD or even some of the free ones. Thanks again. I feel bad for not knowing that on my own, I thought I had already tried everything. Using that method, I'm starting to think VLC is one of the best programs for playing DVD's now, if not the best, even if it's just for the simple fact that it uses far less memory and resources and has less loading time and more speed. However, it also gives you some options that no standard DVD program would have. -
VLC is an outstanding media player but as far as playing DVD's it doesn't play everything, especially within menu cells. I wouldn't recommend it to test out DVD's that you create or modified and going to burn to disc. But if all you want to do is view the movie and that's it, you can't go wrong. IMO where VLC shines is its ability to play broken files. When I'm encoding something to DVD I can open up the still-encoding file in VLC to see how it's turning out. But as far as a software dvd player that will simulate hardware dvd player, I would go with MPC or PowerDVD.
Mpeg Streamclip Problem (VOB files twitch)
By Keys in forum MacReplies: 2Last Post: 10th Aug 2009, 12:39 -
Problem with Audio when playing VOB dvd files
By rbrown871 in forum AudioReplies: 9Last Post: 8th Dec 2008, 09:36 -
Problem with .vob .mpg files and editing
By rainyday in forum Newbie / General discussionsReplies: 7Last Post: 16th Apr 2008, 23:51 -
vob files problem
By warlock110 in forum Newbie / General discussionsReplies: 6Last Post: 23rd Mar 2008, 11:32 -
Problem with Vob files
By seven_deuce offsuit in forum Newbie / General discussionsReplies: 4Last Post: 26th Dec 2007, 10:04
