help! i'm old and technically inept!! i have a dvd player thats about three years old but that has hardly ever been used and has been sitting on a shelf gathering dust. i bought myself a nice new tv and decided to hook up the dvd player but it wont play! i put a dvd in, it thinks about it, then spits it back out again. any idea what the problem might be? its an RCADRC310N. cheers!
You said it, it's been sitting on a shelf gathering dust! Some of that dust will be inside it too. Run a cleaning disc through it and it should be fine.
I have a DVD player that was working perfectly, it was left for about a year and didn't work when I next tried it. Lens cleaning disc bunged in and it was back to normal again. -
thanks for your responses, however, how can i put the cleanign disc in when the machine wont accept a disc? should i open the machine up and clean it that way?
I think the dvd cleaner will clean the lens in less than1 min only(if thats the only issue you have ).buy it from wal-mart .if it doesn't work return it
downloaded video wont play in my dvd player
By KingRich70 in forum Newbie / General discussionsReplies: 17Last Post: 10th Jan 2011, 18:52 -
My MENU wont autoplay on DVD player
By GREENDIVERS in forum Newbie / General discussionsReplies: 0Last Post: 9th Jul 2008, 11:39 -
home made DVDs wont play on all stand alone DVD players. why?
By suomiaussie in forum Authoring (DVD)Replies: 12Last Post: 2nd Jan 2008, 20:59 -
Why wont windows media player play any audio from my created dvds
By thnkbg in forum Authoring (DVD)Replies: 1Last Post: 17th Aug 2007, 10:30 -
Copied dvds wont play on my PC
By Rgalan in forum Newbie / General discussionsReplies: 10Last Post: 21st May 2007, 16:34
